starter motor too powerful?
70,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JUJU201731
  • 28 POSTS
starter motor is sometimes too strong. problem seems more noticeable when weather is colder. should i be worried? m currently having some engine issue, most likely due to the fuel system. Could it be related to the fuel system?
Nov 25, 2022 at 12:38 PM
  • 110,248 POSTS
I think this is the first time I ever heard the starter is too powerful. Usually, it's the opposite. I have a question. What does it do that leads you to think it is too strong? I ask because the system is 12v and that doesn't change. Does it turn too fast?
Also, is it possible for you to record it and upload it so I can hear it as well? Also, let me know if this has a push button start or a traditional key so I can look through the correct starter circuit wiring schematic.
Let me know
Nov 25, 2022 at 1:18 PM
JUJU201731
  • 28 POSTS
i can tell from hearing starter turning too fast it does not feel good. its traditional key. i think it happens when the weather is cold. However, it doesn't happen if i plug in key to turn radio on and then wait a few seconds to turn on engine. i also had one occasion where battery randomly shut off after driving and another occasion where the radio shut down and turned back on during driving. (Battery only 3 months old)
Nov 27, 2022 at 12:10 PM
  • 55,673 POSTS
Can you please shoot a quick video with your phone so I can hear the engine crank over? that way I can tell for sure what's going on.. You can upload it here with your response.
Nov 28, 2022 at 3:00 AM
