Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Engine
Starter
Symptoms
Grinding
Starter makes loud grinding noise
1998 CHEVROLET BLAZER
200,000 MILES • 4.6L • 6 CYL • 2WD • AUTOMATIC
JEDCASTO
MEMBER
1 POST
I tried putting shims in, but still makes noise.
Jan 25, 2020 at 2:43 AM
Experienced Mechanic
Good afternoon,
Did you replace the starter? The end gear could be damaged.
Did you check the flywheel for any damage? That is a common issue. check the teeth for any grinding off of the teeth.
Images (Click to enlarge)
Jan 25, 2020 at 3:23 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
