starter just clicks
200,000 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
LARRY 35773
  • 7 POSTS
Starter just clicks and the dash lights go off for a few seconds then back on put new starter/battery/fuse in the hot post wire/fuse and the park neutral switch. Tried crossing the starter out still just click when it stopped starting. I tried to start it and it was like the battery was dying meaning it turned over and all then just clicked. Any help? Thanks
Feb 11, 2017 at 8:33 AM
STEVE W.
  • 15,423 POSTS
Check the cable connections on both the positive and negative cables. Also, make sure the body ground is okay. To quickly test the grounds you can use a set of jumper cables to connect the battery negative post to the engine block and the body to the engine block. See if anything changes.
Feb 11, 2017 at 4:13 PM
LARRY 35773
  • 7 POSTS
Okay, Steve I will check tomorrow weather permitting and let you know. Thank you
Feb 11, 2017 at 4:18 PM
LARRY 35773
  • 7 POSTS
Hi Steve, just letting you know I had a gut feeling that the starter was bad even after Autozone checked it and said it passed. so I bought another starter put it on and Voom Voom it stared right up. Thanks Steve, I will be back I am sure. I know cars but sometimes we all need help Thanks again, Larry
Feb 15, 2017 at 5:05 AM
STEVE W.
  • 15,423 POSTS
That has been happening a lot lately. Between the sales droids that cannot look up or test parts and the crap they are selling as parts I think they are trying to force everyone to buy new cars. At least you got it repaired. Now if you had mentioned who tested the starter.
Feb 15, 2017 at 6:48 AM
LARRY 35773
  • 7 POSTS
I hear you. I have used Autozone for years to test battery's/alternators/starters never have I ever had this problem until now. Needles to say I will do most if not all of my testing from now on. Thanks a lot Steve.
Feb 15, 2017 at 6:52 AM
STEVE W.
  • 15,423 POSTS
Thank you for using 2CarPros.com.
Tell your friends, family and anyone you like about us and please return with any auto related questions. we are here to help.
Feb 15, 2017 at 7:40 AM
