Starter issue, battery is good?
170,000 MILES • 2.4L • 4 CYL • AUTOMATIC
TWAZOLE
I do not know if it is related but the last two times that I went to get gas my car did not start right away. After getting gas and driving home the last time, with no issues on the way.. the next morning it did not start. I checked my battery and had proper voltage, as well as the 12 volt constant and the trigger wire.. the flywheel was not seized.. or however you say that forgive me I am not familiar with the term... And I don't know what to do to troubleshoot from here please help me
Jul 17, 2023 at 3:43 AM
  • 55,770 POSTS
Most of the time the starter motor will be going bad, but I would start by load testing the battery and cleaning the battery cables.
Here are guides that can help us fix the problem:
and
If the guides above, don't help, please go over this guide:
Here is how to change the starter out. Check out the images (below). Please let us know how it goes.
Jul 17, 2023 at 11:14 AM
TWAZOLE
I have done that,and the starter works outside of the car.
Jul 18, 2023 at 12:03 AM
TWAZOLE
I turn the key and get just a click not even a crank.
Jul 18, 2023 at 12:05 AM
TWAZOLE
Could a bad ground possibly be the fault?
Jul 18, 2023 at 12:07 AM
  • 55,770 POSTS
Yes, for sure a bad ground cable or connection to the engine block can cause the issue. I would make sure the cable is in good shape and the connection is clean and tight. Check out the images (below). Please let us know how it goes.
Jul 20, 2023 at 2:45 AM
