Starter issue
240,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
RICKSZ
I have had starter issues with this van, usually the drive not fully engaging fully. Have checked voltage to starter which was good. I have changed this starter four times with supposedly new starters. The van starts great for a few months, then back to the same problem. The parts store says its issues with the van not their starters. But why as soon as a new starter is installed no issues for months?
Oct 13, 2018 at 1:14 PM
  • 55,841 POSTS
It sound like the flex plate is wrong out which takes the starter out. Here is a guide to help and a video to show you what you are in for when changing the flex plate. It not the same car but the process is the same.
and
https://youtu.be/3vJAojsrfuU
If you remove the starter and take a picture of the explicate teeth I can tell for sure.
Cheers, Ken
Oct 15, 2018 at 10:26 AM
