When I crank, the starter does not turn over the engine?
111,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
MARIUSZ HEREJCZAK
It engages, but I only hear the noise of the starter spinning fast, without engaging the motor. Do i need to change solenoid, starter motor, or booth?
May 26, 2023 at 3:06 PM
  • 110,246 POSTS
It sounds like the starter Bendix has failed. The Bendix is what kicks the starter drive gear out to connect with the flex plate and turn the engine. In this case, I would replace the starter motor.
I attached the directions below.
Let me know if this helps or if you have questions.
May 26, 2023 at 5:14 PM
