Installed a new starter. Hooked up the battery cables and everything started smoking. What's causing this?
Apr 24, 2023 at 2:12 AM
✓Experienced Mechanic
It sounds like the starter you installed is defective or the wiring to the starter has been installed incorrectly. Here is a guide to help you step by step for the starter replacement and instructions in the images below to show you how on your car.
