Starter will not engage the flywheel
TRISTON C. G. THACKER
  • 2002 SATURN L200
  • 2.2L
  • 4 CYL
  • 150,000 MILES
My car shut off on the way to work. I replaced the alternator, tested the battery, both are good now. My starter for some reason will not engage the flywheel. I had it tested at AutoZone and they said it was good. I put it back on with a fully charged battery and it still just spins. Please help, any ideas are appreciated.
Friday, January 19th, 2018 AT 1:13 AM
  • 52,797 POSTS
Good morning.
Are you saying the starter motor turns but does not turn the motor?
If it does, two possibilities:
1. Bendix drive bad in starter.
2. Flywheel damaged on the motor.
Friday, January 19th, 2018 AT 3:38 AM
  • 8 POSTS
Flywheel is good, but if the Bendix is bad would it pass an AutoZone test?
Friday, January 19th, 2018 AT 2:46 PM
  • 52,797 POSTS
Sure, the starter would turn fine but would not engage the flywheel.
Friday, January 19th, 2018 AT 2:53 PM
  • 8 POSTS
I will replace the starter, I will get back to you if it fixes the problem. Worst case scenario at least I will get a refund and the old one back if it does not work.
Friday, January 19th, 2018 AT 9:00 PM
  • 52,797 POSTS
Keep us updated and thank you for visiting 2CarPros.
Sunday, January 21st, 2018 AT 5:15 AM
  • 8 POSTS
I rebuilt the starter but it still does the exact same thing. Is it possible the ignition switch is bad?
Wednesday, January 31st, 2018 AT 10:01 AM
  • 52,797 POSTS
Did you replace the bendix drive at the end of the shaft?
No, you have power and it turns
Wednesday, January 31st, 2018 AT 10:40 AM
  • 8 POSTS
Replaced the starter. The engine will turn but won't crank. I am getting spark. All fuses are fine.
Saturday, February 3rd, 2018 AT 3:36 PM
  • 52,797 POSTS
The engine will turn but will not crank? If the engine is turning, it is cranking. Please explain
Sunday, February 4th, 2018 AT 5:32 AM
  • 8 POSTS
The engine will turn but it will not start. I turn the key to the start position and everything moves, it just wont start.
Sunday, February 4th, 2018 AT 10:20 AM
  • 52,797 POSTS
Ok, thanks.
Did you check for spark and fuel? That is the next step.
Sunday, February 4th, 2018 AT 7:06 PM
  • 8 POSTS
Checked all 4 pins on the coil pack, I have spark. Took the plugs out and they smelled like gas and the fuel pump kicks on.
Sunday, February 4th, 2018 AT 8:12 PM
  • 52,797 POSTS
OK, so you have spark at the plugs?
You need to check the actual fuel pressure to be sure it is putting out the proper pressure.
Monday, February 5th, 2018 AT 3:16 AM
