starter gets stucked when turning car on
37,000 MILES
CABRIL
At the time when I try to start the vehicle and turn the key all the way to the right is sounds normal, but then the starter sound gets stucked and after a while it turns off. I already checked the battery and its ok, the window, lights, radio, etc... Works fine
Jun 4, 2013 at 11:20 AM
  • 110,251 POSTS
Can you explain what you mean by the starter getting stucked?
Jun 7, 2013 at 10:15 AM
CABRIL
Hi and thanks for replying, it sounds when the gas is about to make combustion, so its not fissically, a mechanich tells me it may be the gas filter o the gas pump..
I will like to know what do think? How often does these parts have to be changed?
Regards
Jun 7, 2013 at 11:20 AM
  • 110,251 POSTS
I have to be honest, I don't see how the fuel filter will affect the starter. You should replace the filter around every 30K miles.
Aug 8, 2013 at 12:17 PM
