what would cause the 10 amp crank fuse to melt? I keep having to replace the ignition switch. I have replaced the ignition switched four times already.
It does not blow in the fuse box just melts it and after a while the ignition switch fails but after I replace it everything works fine for six months then it will melt the fuse again. But it does not pop it and I'm back to square one.
Jan 24, 2019 at 4:05 AM
