Starter cable melting
160,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
MOTMOT
I drove my car to a local auto parts store, after about 1/2 hour later I went to start it and the battery was dead, so I bought a new battery and when I turned the key all the way The positive cable going to the starter went up in smoke,
my car has 3 positive cables going to the positive post, 1 to the starter,1 goin to the alternator, and 1 goin to the fuse box under the hood, Since all 3 are hooked together at the pos.post, How can just the starter cable fry and not the other two ?? I know alot but this one's got me stumped,, please only respond if you know for sure what it is. thanks
Apr 2, 2021 at 3:57 AM
This is because you had high resistance in this one cable. If you want to confirm this then you can do what is called a voltage drop test on the wiring.
Basically you put your meter leads on the ends of this wire and then crank the engine. More then likely you will see a couple volts. You should not see much at all but you are seeing is the amount of voltage that the wire is using. In more cases you should see a couple tenths of a volt on this test on a cable like this as we want all the voltage getting to the starter for it to use.
What I would do is change the starter and then do this test again just to make sure the wire is okay.
The only other thing that would cause this is a starter issue but if this is operating properly then I doubt it is the issue.
I attached the process for this just in case you need it.
Let us know what you find.
Thanks
Apr 3, 2021 at 12:20 PM
MOTMOT
Thank you for replying to my question. I got a new starter installed and the problem seems to be solved.
Apr 5, 2021 at 5:35 AM
That is great. Thanks for the update. Glad it is resolved and that you provided that info for others. Please come back to 2CarPros.
Apr 6, 2021 at 11:57 AM
