Starter bolt locations
124,970 MILES • 3.1L • V6 • 2WD • AUTOMATIC
JOE ORIGINALES
I needing to replace the starter on my dad's car, but cannot find where the other bolts are located. I've only found one bolt.
Sep 22, 2019 at 7:24 AM
  • 110,248 POSTS
Welcome to 2CarPros.
There are two. I attached a picture so you can see locations. Once you remove the bolts, then remove the motor by rotating the solenoid side toward the vehicle. I did note that you said it is a 3.1L. The V6 offered was a 3.3L. That is what the picture is from. Please let me know if something is different.
Let me know if this helps.
Sep 22, 2019 at 12:57 PM
