Starter battery
2004 MAZDA MPV
170,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
JEREMY DOUGLAS NOBLE
My battery is weak and has hard time turning starter over. With a jump it starts but now it wont turn over at all. Alternator is good I checked. Is it starter?
Nov 18, 2016 at 2:22 AM
JIS001
  • 3,412 POSTS
First verify your battery is not the problem. Also make sure cable ends are bright shiny and clean. If there is corrosion that will give you problems. Most auto parts store can charge and test your battery for you. They do bench test on starters also but I find those test unreliable since out the vehicle they always work fine (after all, it is not trying to turn an engine over). So start with checking the battery. Here is a link on how to load test one.
Nov 18, 2016 at 3:06 AM
The lights are not dim. I believe alternator is good and I put new battery in it and still wont even turn over.
Nov 18, 2016 at 3:54 AM
JIS001
  • 3,412 POSTS
As stated earlier, have the battery checked to be 100% sure. If it is good with a volt meter check for battery voltage at the starter battery cable. If no good make sure there is no corrosion. If good then unplug the starter signal wire. With volt meter and with someone holding the key to the run position you should see battery voltage. If you do then replace the starter.
Nov 18, 2016 at 5:29 AM
JOHNNY G.JR
  • 320 POSTS
Cables might have excessive corrosion inside of them if you do not get the same voltage at starter cable post as you have on battery.
Nov 18, 2016 at 9:20 AM
  • 55,433 POSTS
Hey JEREMY,
It sounds like the starter has gone bad, here are some guides that will show you how to test and replace it.
and
Please let us know what you find so it will help others.
Best, Ken
Nov 20, 2016 at 9:09 AM
