starter and horn are working together
140,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
CCTMEDIC
when I start the vehicle the starter works and the horn blows, while running if I try to honk the horn the starter will engage. I have removed the starter relay to prevent damage to the starter. I removed the signal wire to the starter and when I try to start the engine the horn still sounds.
Aug 19, 2014 at 11:27 AM
WRENCHTECH
  • 20,758 POSTS
Sounds like there is an issue with the wiring somewhere. Those 2 signal wires could be shorted together somewhere along the way.
Aug 19, 2014 at 7:41 PM
