Where is the starter located?
125,000 MILES
RAYMOGRAN
Location of starter.
Mar 21, 2023 at 10:07 AM
  • 110,244 POSTS
The starter motor is located at the front section of the engine closest to the radiator. You will find it at approximately oil pan height right where the engine and transmission join together.
When you do the replacement, make sure the battery negative terminal is disconnected prior to starting the procedure.
Let me know if you have other questions or if I can help in any way.
Mar 21, 2023 at 12:52 PM
