Starter not working properly
248,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JOHN TOMADAKIS
I turn the key to start the car and if it doesn't start right away the start makes a whining noise likes it's continually spinning and not engaging. I have to pull the negative wire off so it stops. And when I put the wire back on it still makes that noise . And I can't start it.
Dec 16, 2019 at 9:18 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Quick question... When the starter motor continuously free spins as you stated the key is off right ? From what it sounds like you take the key out of the ignition and then have to disconnect the battery to get it to stop.There might be a shorted contact in the starter motor solenoid. Here is a tutorial to show you how to remove/replace a starter motor:
Most local auto parts stores will test your starter motor for free.Hope this helps and thanks for using 2CarPros.
Dec 16, 2019 at 10:34 PM
