Starter not working properly
220,074 MILES • 5.3L • V8 • 4WD • AUTOMATIC
JBEARD24
The starter will spin the flywheel once and then free spins and sometimes it’ll turn it once and nothing happens.
May 30, 2022 at 9:21 AM
  • 110,251 POSTS
The Bendix on the starter is failing. When you engage the starter, an electromagnet inside the solenoid engages and pushes out the pinion gear in the starter and in turn makes contact with the flywheel and turns the engine.
If it is kicking in and out, the starter should be replaced. Here is a link you may find helpful:
If you look below, I provided the directions specific to this vehicle.
May 30, 2022 at 1:56 PM
JBEARD24
This would be my third starter replacement in 2 weeks, what is causing my truck to go through so many starters?
May 30, 2022 at 11:07 PM
  • 110,251 POSTS
If you are getting a remanufactured part from the same company, it could be an issue with how they are rebuilt, or the parts used in the rebuild.
Did you get the same brand from the same place?
Keep in mind, based on what it's doing, there really isn't any other cause. The starter turns indicating power is present direct from the battery to the motor, and the starter is actuated which indicates power is being sent to the S terminal on the starter solenoid. Since these are both happening, but the Bendix kicks out and the motor still spins, the problem is in the solenoid/Bendix.
Let me know if it is the brand. If it is, try a different brand and see if that makes a difference.
Also, if you could record what it is doing and upload it for me to hear, I should be able to confirm what is happening.
May 31, 2022 at 12:58 PM
