Will not start with replacement key
150,000 MILES • 5.0L • V8 • RWD • AUTOMATIC
DABLUNT
  • 5 POSTS
I lost the key to the car. Took the VIN number to the dealership to get a new one. I put the key in and I cannot get it to turn over. Do I have to program the new key? Dead battery?
Mar 17, 2017 at 5:31 AM
WRENCHTECH
  • 20,760 POSTS
Does the key have a visible pellet in it?
Aug 17, 2019 at 10:01 AM
DABLUNT
  • 5 POSTS
A chip? Yes
WRENCHTECH
  • 20,760 POSTS
Then that means you have to replace the Passkey module. They are "one time" programming and cannot be reprogrammed. You can't get a used one, it has to be a brand new one.
DABLUNT
  • 5 POSTS
Could you send me a link on how to fix this. I can't move it...
WRENCHTECH
  • 20,760 POSTS
New decoder modules are unprogrammed. Before the system will function properly after a new module has been installed, it must be programmed to the code that matches the customers keys. Install the new, unprogrammed decoder module. Insert one of the customers keys in the ignition lock cylinder and turn it to the "ON" position. Start the engine at this time to verify system operation. Observe the security indicator lamp. The indicator should come on and stay on continuously until the next ignition cycle. If the lamp does not go out when the ignition is cycled off and then on again, repeat step 2 thru 3. If vehicle still will not start, refer to diagnostic procedures. The passkey decoder module is located behind the R/H side of the I/P. https://www.2carpros.com/images/external/42279468.gif
