Starter does not disengage
30,000 MILES • 4 CYL • 2WD • MANUAL
SLEEVE44
  • 12 POSTS
When I start my truck, the starter does not disengage. Could I have it wired up wrong?
Nov 6, 2018 at 8:04 PM
Good morning.
It is possible.
Does it ever disengage?
Can you post a picture of the solenoid wiring?
It could also be a stuck relay or the starter motor itself.
Nov 6, 2018 at 10:25 PM
JONNYB1963
  • 263 POSTS
One quick question. Is this a new starter that you just installed or one that has been working and just started doing this?
Jon
Nov 6, 2018 at 10:36 PM
SLEEVE44
  • 12 POSTS
One that has been working.
Nov 6, 2018 at 11:04 PM
SLEEVE44
  • 12 POSTS
The one that was already on there.
Nov 6, 2018 at 11:11 PM
JONNYB1963
  • 263 POSTS
Thanks for that. That is a pretty low mileage vehicle for a 1996 by the way! I am taking it on faith that the starter motor itself is no still cranking the engine and that it is just that the gear is still engaged in the flywheel.
If the starter motor never stops trying to crank the engine (as if you never let go of the key I mean) Then that would be an electrical problem as described above.
Two mechanical answers can happen to make this happen:
1. The coil spring on the Bendix has failed and is no longer able to pull the starter gear away from the flywheel. (In this case you would need a new starter)
2. The second one is not possible since the starter was already working but involves the center to center distance between the starter and flywheel is too tight. (some older GM starters needed to be shimmed but Ford does not use this system).
To see if the spring is broken on the starter you will need to remove it. Disconnect the battery before removing it. Remove the two bolts on the starter and slide it out of the housing. If the spring is broken you should very easily be able to move the gear in and out by hand and once it is out (extended) it should pull itself back in. if not, that is your problem. New starter needed!
Nov 6, 2018 at 11:35 PM
SLEEVE44
  • 12 POSTS
Thank you, that sounds like it could solve the problem.
Nov 6, 2018 at 11:42 PM
Before jumping into replacing the starter make sure the relay is releasing the power to the solenoid. It may be as simple as a relay.
Do not want you to spend a lot of money on something that will not fix it.
Nov 6, 2018 at 11:45 PM
SLEEVE44
  • 12 POSTS
Where exactly is the relay?
Nov 6, 2018 at 11:47 PM
Left front out by the headlight is a relay box.
Picture attached.
Nov 6, 2018 at 11:54 PM
SLEEVE44
  • 12 POSTS
I do not see a relay in front by the light. Could it be in the fuse box?
Nov 7, 2018 at 7:29 AM
It will be in a relay box, yes.
Nov 7, 2018 at 7:37 AM
SLEEVE44
  • 12 POSTS
I see the relay box up by head light, but it only houses relays to blower and the window washer.
Nov 7, 2018 at 7:39 AM
There should only be one blower relay.
Have someone try to start the truck and see if you feel one of the relays click. If you are worried about the starter sticking, then remove the small wire on the starter solenoid. That will not stop the relay from working.
Nov 7, 2018 at 7:43 AM
SLEEVE44
  • 12 POSTS
Is there any other place the relay might be?
Nov 10, 2018 at 1:54 AM
SLEEVE44
  • 12 POSTS
Can you tell if the solenoid is wired right?
Nov 10, 2018 at 4:18 AM
Wow! No it is not.
The positive battery cable goes to one stud. all the other big eyelet wires go on that stud as well as they feed other systems.
The wire to the starter motor goes on the other stud. No other wire should be on there. That is why you have your issue.
The little wire is good.
Nov 10, 2018 at 4:54 AM
SLEEVE44
  • 12 POSTS
Thank you very much.
Nov 10, 2018 at 4:56 AM
You are welcome.
Always glad to help.
Nov 10, 2018 at 5:03 AM
SLEEVE44
  • 12 POSTS
That solved the problem.
Nov 10, 2018 at 6:54 AM
SLEEVE44
  • 12 POSTS
Now I have another problem. I cannot get my fuel gauge to work.
Nov 10, 2018 at 6:56 AM
Okay, sorry, traveling
Did you check for power to the sender at the fuel tank?
Diagram attached.
Check the yellow/white wire for power with the key on.
Nov 11, 2018 at 10:52 AM
