Starter?
180,000 MILES
BWRIGHT26
  • 5 POSTS
Does this sound like I need to replace my starter? Ruled out battery. Don't think it's fuel pump bc I can hear it run and I've tried priming it by cycling the key and it doesn't make it start any faster. It eventually starts and runs fine afterwards. No CEL no codes
Mar 7, 2026 at 2:06 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Keep the reported starting improvement separate from the later code. For P0011, obtain the engine-specific diagnostic procedure and document the oil specification, level and relevant test results before authorizing timing-system work.
Guidance references and applicability
2CarPros: Original discussion 1712284 https://2carpros.com/questions/starter-70977349 Source for reported history and outcome. Contributor suggestions are not independently confirmed diagnoses. Attachments were not verified.
Read the replies · Discussion summary and reported outcome
CANNON1349
  • 861 POSTS
Hello, yes this sounds like the starter is spinning but not engaging. Let us know if we can help.
William
Mar 7, 2026 at 11:26 PM
BWRIGHT26
  • 5 POSTS
I replaced the starter this morning and runs like a dream now! Thank you
Mar 8, 2026 at 12:20 AM
CANNON1349
  • 861 POSTS
My pleasure, feel free to use the site anytime, we are here to help.
William
Mar 8, 2026 at 12:22 AM
BWRIGHT26
  • 5 POSTS
Ok so another problem I'm now having is a P0011 code on my 2013 Sonota. Had oil changed and cleaned the VVT solenoids both intake and exhaust. Still throwing the code. Any suggestions?
Mar 8, 2026 at 9:02 AM
CANNON1349
  • 861 POSTS
Did you do the repair or did you pay a shop to do it? I have seen bits of dirt, seals, etc get caught in the tiny passages just below the VVT solenoids. If everything looks good and clear, it is possible the timing chain is stretched. But you would need to disassemble to verify.
William
Mar 8, 2026 at 10:40 AM
Discussion summary
Starter?
The owner reported difficult starting followed by normal running. After replacing the starter, the owner said the vehicle ran well. A later update raised a separate P0011 concern on the 2013 Sonata despite an oil change and cleaning both VVT solenoids.
Reported outcome: The owner reported improvement after starter replacement. The later P0011 concern remained unresolved.
The original sound could not be evaluated from this text export. Debris and timing-chain wear were proposed explanations for the later code, not confirmed findings.
Read the original discussion
