starter
100,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
ROEANNA DAVIS WRIGHT
Can I take a starter off a 1996 Chevrolet Blazer and use it on the truck listed above?
Aug 16, 2017 at 1:40 PM
  • 55,710 POSTS
If they have the same size engine it should work. check the offset of the of the starter gear in relation to the starter bolts that will let you know for sure.
Here is a guide the will help you get started:
and
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Cheers, Ken
Aug 17, 2017 at 8:21 AM
