Starter replacement
90,000 MILES • 2WD • AUTOMATIC
SCOTT123456
Is it very difficult to replace starter on the car listed above NL model?
May 1, 2020 at 7:25 AM
  • 110,246 POSTS
It isn't and easy one simply because of location. It calls for 4.3 hours of labor. Here are the directions. The attached pics correlate with the directions.
________________________________________________________________
1999 Acura RL V6-3474cc 3.5L
Removal And Installation
Vehicle Starting and Charging Starting System Starter Motor Service and Repair Procedures Removal And Installation
REMOVAL AND INSTALLATION
1. Make sure you have the anti-theft code for the radio, then write down the frequencies for the radio's preset buttons.
2. Disconnect the battery negative terminal first, then the positive terminal.
NOTE: The PCM memory setting is needed after reconnecting the battery.
pic 1
3. Raise the coolant reservoir, then remove the battery and battery base.
4. Remove the alternator belt and alternator.
5. Remove the left exhaust manifold cover.
6. Remove the left damper fork.
7. Disconnect the left suspension lower arm ball joint.
8. Remove the left driveshaft.
pic 2
9. Remove the transmission stop collar, then remove the exhaust pipe A.
10. Remove the front mount mounting bolts.
11. Attach the chain hoist to the engine.
pic 3
12. Remove the left engine mount bracket.
pic 4
13. Disconnect the starter cable and BLK/WHT wire, then remove the starter.
pic 5
14. Install in the reverse order of removal.
NOTE: When installing the starter cable, make sure that the crimped side of the ring terminal is facing out.
15. Enter the anti-theft code for the radio, then enter the customer's radio station presets.
I hope this helps. Let me know if you have other questions.
May 1, 2020 at 11:54 AM
