starter not engaging
300,000 MILES • 0.5L • 4 CYL • 2WD • MANUAL
ANNETTERHOADES
put new starter on, still spinning not engaging.
Feb 19, 2017 at 6:35 AM
JDL
  • 16,098 POSTS
Did you check the old starter to see if would kick out the drive gear and spin? Did you check out the flywheel teeth?
Usually, I can lay the starter motor on the ground, hook up jumper cables properly between starter motor and battery, It will kick out the drive gear and spin, laying there on the ground. Of course that is no load test.
Feb 19, 2017 at 7:14 AM
JDL
  • 16,098 POSTS
I just wanted to add, some makes an models may use shims. Could be something wrong with flywheel?
Feb 19, 2017 at 7:17 AM
