starter bolts length
200,000 MILES • 5.0L • V8 • 2WD • MANUAL
STACYLYNN7
  • 32 POSTS
Starter bolts are too long on this c1500.
Oct 24, 2016 at 1:15 PM
  • 55,711 POSTS
Hi STACYLYNN7,
Yes, they made several starters that fit that truck and some of them used shorter starter bolts, you need to get another starter or use shorter starter bolts.
Please let us know what you find so it will help others.
Best, Ken
Oct 24, 2016 at 1:23 PM
STACYLYNN7
  • 32 POSTS
Thanks, what is the problem too bad the dealer at AutoZone did not tell me that now when it starts after it is running it still sounds like starter is running.
Oct 25, 2016 at 4:46 AM
  • 55,711 POSTS
Yep, the starter is bad and you need another one, may I suggest getting you money back and getting a AC Delco unit from Amazon. You will have better luck with an factory unit.
https://www.amazon.com/TYC-1-06449L-New-Starter/dp/B00BG3GTE6/ref=au_as_r?_encoding=UTF8&Make=Chevrolet%7C47&Model=C1500%7C424&Year=1995%7C1995&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=6&vehicleType=automotive
Double check the fit and engine size.
Also Rockauto.com has AC Delco
Let me know how it goes.
Best, Ken
Oct 25, 2016 at 5:20 AM
STACYLYNN7
  • 32 POSTS
I just bought one.
Oct 25, 2016 at 5:56 AM
STACYLYNN7
  • 32 POSTS
It is the one I just bought how can it be bad?
Oct 25, 2016 at 5:58 AM
RENEE L
  • 1,260 POSTS
Hi Stacylynn7,
Unfortunately it is not uncommon for a new part to be bad right out of the box. I agree with Ken return it to where you purchased it from and either get your money back or try another one.
Let us know how this turns out.
Kindest regards,
Renee
Admin
Oct 25, 2016 at 7:34 AM
