Yes, they made several starters that fit that truck and some of them used shorter starter bolts, you need to get another starter or use shorter starter bolts.
Please let us know what you find so it will help others.
Best, Ken
Oct 24, 2016 at 1:23 PM
STACYLYNN7
MEMBER
Thanks, what is the problem too bad the dealer at AutoZone did not tell me that now when it starts after it is running it still sounds like starter is running.
Oct 25, 2016 at 4:46 AM
✓Experienced Mechanic
Yep, the starter is bad and you need another one, may I suggest getting you money back and getting a AC Delco unit from Amazon. You will have better luck with an factory unit.
Unfortunately it is not uncommon for a new part to be bad right out of the box. I agree with Ken return it to where you purchased it from and either get your money back or try another one.
