Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chrysler
New Yorker
Engine
Starter
Replace/Remove
Starter location
1972 CHRYSLER NEW YORKER
6,100 MILES • V8 • 4WD
LISA27
MEMBER
1 POST
Where is the starter located at?
Oct 13, 2018 at 6:36 AM
Experienced Mechanic
Good evening.
The starter is under the car, left side and is located where the engine and transmission meet together.
There are two wires you need to remove after you remove the battery cable. Then there are two 5/8 bolts that secure it to the transmission.
Oct 13, 2018 at 10:14 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
