Start Up issues
108,000 MILES • 3.0L • AWD • AUTOMATIC
NANCY LAPP
Went to start up car. It turns over but does not seem to be getting any fuel. I changed both the pump and filter. Still not starting. Will start when starter fluid is sprayed into it but will not stay running
Sep 5, 2016 at 7:20 AM
AL514
  • 5,697 POSTS
Check to see if you have any power and a good ground to the fuel pump. You can check power with a basic test light and go from there. It could be a few different things, ie, bad fuel pump relay, wiring, fuse etc.
Sep 5, 2016 at 7:37 AM
  • 55,721 POSTS
Here is a guide that can help you
Please let us know what you find so it will help others.
Best, Ken
Sep 14, 2016 at 11:07 AM
