Intermittent no crank, no start
37,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
JESTEP1966
  • 9 POSTS
When I try to start I hear a series of clicks then dash lights flash, tachometer and speedometer jump up then go down.no crank. it does not happen all the time mostly when it has been sitting for a day or two.
Oct 31, 2020 at 3:23 AM
  • 110,248 POSTS
If it eventually does start, the first thing I would check are the battery terminals. If they are loose or corroded, it can cause this.
Take a look through this link and let me know if it helps:
Oct 31, 2020 at 12:35 PM
