Starting Problem
115,000 MILES • 1.7L • 4 CYL • TURBO • FWD • MANUAL
WILLGITTINS94
I went to start my car, the engine cranks and the car records 600rpm but won't start. When I turn the key to do this the wire from the solenoid keeps catching fire. Occasionally this doesn't happen and the car starts and runs fine. I can bump start the car and it runs fine. Is this a starter that needs replacing or maybe something bigger. Any help would be much appreciated.
Aug 29, 2016 at 3:26 AM
RENEE L
  • 1,260 POSTS
Yes the starter needs replacing. The resistance in the solenoid is too high causing the excessive heat.
Sep 1, 2016 at 3:30 AM
