Starting issue
234,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MARCOS310
It starts once fine and runs great. Once I turn off the car it wont start again right away it will take like twenty to thirty minutes just to turn it back on and that's a maybe, because the battery runs out. I have changed the spark plugs, the cam and crank sensors, timing chain, flex plate, and also has a rebuilt transmission. i do not know what else the problem can be. There is no check engine light on and nothing pops out in the scanners.
Jan 16, 2019 at 2:17 AM
  • 110,251 POSTS
Honestly, that is a typical description of a bad crankshaft position sensor. However, you replaced it. Take a look at this link:
Next, take a look through this link:
With that in mind, what I need you to do is check for spark and fuel to the engine when it refuses to start. One will most likely be missing.
Now, if you have a live data scanner, see if there is an RPM signal when cranking the engine in a no start condition. If there isn't, most likely you aren't getting a signal from the crankshaft.
I attached pictures which show fuel pump testing specific to your vehicle.
Jan 16, 2019 at 11:42 AM
MARCOS310
Thanks for the tips and images Joe. The spark has already been checked and it's fine. The fuel pump is fine.
Jan 16, 2019 at 11:48 AM
  • 110,251 POSTS
Welcome back:
If you have spark and fuel, it should run. Have you checked for an injector pulse?
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Do me a favor, see if it will start for a couple seconds if you use starting fluid.
Let me know what you find.
Jan 16, 2019 at 12:47 PM
MARCOS310
The car runs, it's just the fact that of I turn it off once I have it on and running, it will take me a while to turn it back on.
Jan 16, 2019 at 12:49 PM
  • 110,251 POSTS
Okay, when it won't start, try the starting fluid trick. If it starts for a couple seconds, the problem is fuel related. If it doesn't start with starting fluid, it is ignition related. Once we know which component to focus on, we can dig in. Keep in mind, the car runs so there isn't a compression or timing issue. That only leaves fuel or spark. You may have pressure within the specs, but if the injectors don't get a pulse, it won't run. Lets focus on which is causing the issue, fuel or ignition.
Jan 16, 2019 at 12:52 PM
MARCOS310
okay sounds good, thanks again Joe! really helped!
Jan 16, 2019 at 12:55 PM
  • 110,251 POSTS
Not a problem. Let me know what you find and we can work together on it.
I'll watch for your reply.
Jan 16, 2019 at 1:02 PM
