Flashing check engine light on start up and loss of engine power
90,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
91THUNDERBIRD5.0H.O
Start my car listed above with 5.0 h.o built motor flashes check engine half shuts off and picks it self up. idles high for 2 minutes then idles down runs rough lost half my power. I did change plugs, wires, replaced idle air control valve, didn't fix anything, but it was shot. so I don't know i'm lost. want my power back.
Feb 3, 2021 at 12:47 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Having the check engine light on means you have a fault code stored in your vehicle's computer causing this issue. The first thing you need to do is retrieve the fault code or codes that are causing your drivability issue and low power. Here is a tutorial showing how to retrieve codes:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
After you perform this then we ask you to get back to us with the code information and we can then properly diagnose your car. Hope this helps and thanks for using 2CarPros.
Feb 3, 2021 at 7:47 PM
91THUNDERBIRD5.0H.O
Thanks.
Feb 3, 2021 at 10:38 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Just be sure to get back to us with the code number or numbers and we'll go from there for diagnosis. Hope this helps and thanks again for using 2CarPros.
Danny-
Feb 4, 2021 at 8:15 AM
