No crank no start issue
10,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JESSICA SIMONS
My car will not crank or start but the dashboard lights were flickering before the car shut down.
Nov 17, 2017 at 9:14 PM
STEVE W.
  • 15,409 POSTS
Flickering sounds like a bad connection, either at the battery or the battery itself is failing. Check the cable connections at the battery first, they should be clean of any corrosion and tight. Then check the connections for the other ends of the cables.
Be careful as the batteries tend to weep a bit and the acid can cause damage to clothes, skin or worse.
Nov 17, 2017 at 11:55 PM
