The standard battery keeps draining?
184,000 MILES • 4WD • AUTOMATIC
SLB4SLB
I have the vehicle listed above that I love! The standard battery keeps draining, needs replacing. The current battery is 2018. Can I do this myself? Is it like a standard battery in all cars, or are there special wires, etc., because of the hybrid? Thank you! Sandra
Nov 6, 2024 at 3:58 AM
  • 55,691 POSTS
Hello Sandra,
Yes, you can replace the regular car battery much like a normal battery replacement:
Battery Replacement Process
All systems off!
Disconnect the negative (-) terminal first, then the positive (+) terminal.
Remove any securing bracket or strap holding the battery in place.
Install the new battery, reconnect the terminals (positive first, then negative), and secure it in place.
Here is a guide to help:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Let us know if you need anything else.
Nov 6, 2024 at 8:51 AM
