Codes P0137, P0131, and P0304, stalls, rough idle, misfires?
207,535 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RILEY01031980
I have gas in my oil my car stalls has rough idle misfires it throws codes P0137, P0131, P0304. I have changed O2 sensor, MAP sensor, upstream and downstream stream sensors, spark plugs, and coil packs. I have done fuel assembly replacement. I have changed injectors. I have changed the power control module. I also changed oil pressure sensor because it needed it, but after doing these things it still throws the same codes and acts the same. i don't know what else to do a local mechanic shop charged me $1,000.00 to fix it and that's after I done all the other stuff to the car and they just must have seen an easy target thinking because I'm a girl. I don't know about cars because they have it back doing the same thing on, and Engine light has been on for about a month now it's blinking. please help. oh, and I had oil in my power control module when I took it off and on my spark plugs.
Apr 20, 2023 at 11:44 AM
  • 55,740 POSTS
These Oxygen Sensor codes can be caused by the P0304 - Cylinder 4 Misfire Detected.
P0137 - Oxygen Sensor Circuit Low Voltage (Bank 1, Sensor 2):
P0131 - Oxygen Sensor Circuit Low Voltage (Bank 1, Sensor 1):
P0304 - Cylinder 4 Misfire Detected:
Can I ask you how the engine is running? Can you please shoot a quick video with your phone of the engine running under the hood? That way I can tell for sure what's going on. You can upload it here with your response. From what you have said it only leaves low compression or a fuel injector. Here is a guide to help check the compression and if that is okay to change out the fuel injector in the images below.
Apr 21, 2023 at 9:18 AM
