Stalls when put in gear
90,000 MILES
MILESET
Car starts and runs fine when in park. When i put in gear car buckles and turns off. Car does not do this when it is raining or humid. any ideas?
Jun 26, 2019 at 2:18 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Interesting when it doesn't do it. Rain usually causes electrical problems. However, since that is the case, I think I want you to start with checking for engine vacuum leaks. Here is a link that shows how it is done:
It could also be due to a dirty throttle body. You may want to try cleaning the throttle body. Here is a link that shows how it's done:
Also, take a look through the next link. It discusses common causes of an engine stalling at idle.
https://www.2carpros.com/articles/stall-at-idle
Let me know if any of this helps or if you have other questions.
Jun 26, 2019 at 2:09 PM
