Stalls when it warms up
110,684 MILES • 3.3L • V6 • 2WD • AUTOMATIC
WILLIAM TELL
Stalls when it gets up to temperature and wont start until it cools or unhook battery 5 minutes. gets Dtc's p0123, p1193, p0118 and p1598.
Also if I tap on PCM it will stall also, so I'm sure it's bad.
Sep 3, 2020 at 1:47 AM
This was a pretty common thing on these older Chrysler vehicles. The PCM gets a loose solder joint and it causes this issue. The telltale is tapping the PCM. We need to replace this and then retest all the other issues however, I am sure this will fix them.
I attached the process. You need to program the PCM after replacement unless you find one that the company programs it for you prior to sending it.
Let us know what questions you have. Thanks
Sep 3, 2020 at 3:30 AM
WILLIAM TELL
Yea, I just kept reading all these other questions with same problem and keep hearing crank sensor, BCM, ect, but I know better especially when every time it stalls my ect goes straight to -40°, TPS is at 100% and I didn't even bother to check the IAT sensor. just figured maybe it'll help someone else out one day, but I appreciate it much.
Sep 3, 2020 at 12:38 PM
I am sure it will help others. Thanks for the information and please come back to 2CarPros next time. Also, feel free just to update this thread after this one is fixed just as a confirmation. Thanks
Sep 4, 2020 at 1:02 PM
