Stalls out when driving, code P1685
122,000 MILES • 5.7L • V8 • TURBO • 4WD • AUTOMATIC
GATELAE1
Stalls out then it restart , but then stalls again shortly after. Throws a code P1685. If you disconnect the negative terminal it will reset code and car will be okay for a week or so . Then it will start stalling again. Tried using both key fobs, that’s not the problem. Is the problem the immobilizer?
Feb 23, 2019 at 10:07 PM
GATELAE1
Made mistake it doesn’t have a turbo.
Feb 23, 2019 at 10:24 PM
Good morning,
Can you verify the code? I see nothing for a P1685 for a 2000 ram with a 5.7.
No to the immobilizer. If it was bad, it would not allow it to start. Once it starts, it will or should stay running.
Feb 23, 2019 at 11:13 PM
GATELAE1
You got the year wrong it’s a 2008.
Feb 23, 2019 at 11:36 PM
Sorry, senior moment.
Looked at 2008 for the same and nothing for P1685.
Can you verify the number? I tried it In P, C, B and U and nothing shows for 1685.
Feb 23, 2019 at 11:52 PM
GATELAE1
Roy, I thought that’s was the code number, I had a senior moment also. It said” SKIM Key Invalid”. Or should i wait until it codes again when it stalls out , and then get back to you?
Thanks, Larry
Feb 24, 2019 at 12:18 AM
Yes, when the light comes on again, grab the code and repost it for me.
Feb 24, 2019 at 12:50 AM
