Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Other
Engine
Symptoms
Stall While Driving
stalls out
1989 FORD
100,000 MILES • V8
BOB DUGGAN
MEMBER
1 POST
It is a motor home. After warming up for a few minutes when I touch the accelerator, the engine tries to stall.
Aug 21, 2016 at 7:29 AM
HMAC300
Experienced Mechanic
try cleaning throttle plate on both sides and IAC hole with choke cleaner then check fuel pressure with a gauge.should be 30-45 psi with engine running .
Aug 21, 2016 at 8:26 AM
Add image or video
Ask a new question
Engine won't start
Engine misfire
