Will run and rev in park or neutral. Soon as I put in drive or reverse, it backfires and shuts off. Strong fuel smell. Changed crank sensor.
Apr 21, 2018 at 6:22 AM
WRENCHTECH
✓Experienced Mechanic
The very first step should be to check for stored codes. You can do that without a scan tool by jumping A and B of the diagnostic connector and reading the check engine light flashes.
After that I would test the fuel pressure with an accurate gauge.
