Stalls, I believe has bad injectors
MHOLLAND9522
  • 1992 CHEVROLET LUMINA
  • 96,000 MILES
Idle runs low and will occasionally stall out I had it diagnosed and 2 injectors are bad I am wondering how difficult it would be for me to replace them myself or if I should have a shop do it car makes a bad gas smell when started and usually requires the pedal to start feels like it has lost some of its power since I first purchased it
Monday, July 8th, 2013 AT 9:41 PM
HMAC300
  • 48,601 POSTS
If it has bad injectors you need to pull fuel rail first. Disconnect all electrical conections to injectors, remove rail remove injectors then relube all orings and reinstall rail. You may need to remove the upper intake manifold.
Tuesday, July 9th, 2013 AT 4:58 AM
