Stalls at idle and surges under a load
1997 DODGE AVENGER
153,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
GLENN GILBERT
  • 44 POSTS
I am at my wits end with this car. If it wasn't the only car we have I would get rid of it but cannot afford to at this time.
The problem I have and been having is that the car stalls at an idle at times and also at times when under a load it will surge or buck. I have done the follow to no avail:
1. Replaced the fuel pump relay.
2. Replaced the TPS switch.
3. Replaced the IAC.
4. Replaced the distributor.
5. Replaced the fuel pump.
6. Cleaned the throttle body.
I have no engine light on. I do have a fuel filter but have not put that on yet but I do not think that is the problem. What do you think might be going on with this car?
Apr 8, 2019 at 3:39 AM
Good afternoon,
My first thought is the EGR valve may be stuck partially opening creating a vacuum leak and making it stall.
I would check that valve and see if it is open.
Apr 8, 2019 at 4:17 AM
GLENN GILBERT
  • 44 POSTS
I purchased one a while back when all these problems started and since it looks like a bear to replace I have put that on the side but will do that when I get a chance this coming weekend. Thanks
Apr 8, 2019 at 4:19 AM
You are welcome.
Always glad to help.
Apr 8, 2019 at 4:24 AM
