Shuts off after driving fifteen to twenty minutes
95,678 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
MECCAALEXANDER
Will only come back on after it cools. No relative code.
Jun 25, 2019 at 9:44 AM
  • 110,248 POSTS
Welcome to 2CarPros.
What you described sounds like a bad camshaft position sensor. When the start going bad, heat causes them to short internally. The camshaft position sensor on this vehicle is located in the distributor. See picture 1
Now, before we can conclude what is happening, I need to know if spark is lost to the plugs when the engine stalls and won't start. Here is a link that shows how it's done:
If you find there is spark and the vehicle won't start, see if it will start for a couple seconds using starting fluid. If it does, then the problem is fuel related.
Let me know what you find.
Jun 26, 2019 at 12:32 PM
