Stalls when warmed up
JAMES HERMAN
  • 1995 OLDSMOBILE 88
  • 3.8L
  • V6
  • FWD
  • 125,000 MILES
Starts and runs when cold after it warms up to running temperature about fifteen to twenty minutes it stalls and and will not start again until engine cools.
Sunday, February 26th, 2017 AT 8:37 AM
CARADIODOC
  • 33,916 POSTS
You are describing the typical symptom of a failing crankshaft position sensor or camshaft position sensor. They often fail by becoming heat-sensitive, then they work again after they cool down for about an hour. A good place to start is by having the diagnostic fault codes read and recorded. The people at many auto parts stores will do that for you for free.
Sunday, February 26th, 2017 AT 11:39 PM
