When I start it in the morning it idles fine, but if I don't let it warm up in the driveway, it will stall out within a half a mile. Once it reaches 1/4 or higher on the temperature gauge it will never die for the entire day. Also, this only happens in the mornings when the vehicle has been sitting for over eight to ten hours. I have replaced all plugs, all coils, all intake gaskets, fuel filter, PCV valve, and power steering pressure switch. There are no error codes. Any thoughts? Would a dirty throttle body and IAC cause this issue?
Dec 17, 2018 at 2:05 AM
