My truck is stalling and surging when put into gear I hit the gas and it will stall out but idles fine for the most part has little surges when in idle. Then if it doesn't stall the rpm's will shoot back up and jerk the truck forward then rpm's will surge again. I did some research online I'm thinking it is the TPS , these codes came up on my code reader : SRS B0090 active switch short to battery/ground that came up twice, U1041 loss of ECBM communication , and U1096 lost communication with instrument cluster.. Thanks for your time and I hope you can figure it out from my description.
May 2, 2019 at 12:39 AM
