Stalling problem
200,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
RICKYCLEVINGER
  • 7 POSTS
Vehicle stalls in reverse, during a hard turn, or at a traffic light if the fan is on.
Apr 30, 2018 at 9:16 AM
  • 110,248 POSTS
Has the check engine light come on? If so, start with identifying trouble codes. Here is the process to do it. Once you get the codes, let me know what you find.
https://www.youtube.com/watch?v=b2IJGfImVvw
You will need a scanner to do this. However, many of the nationally recognized parts stores do it for free. Also, when you reply back, I would like to know what the idle speed. It may be an issue with a idle air control valve not increasing the idle under a load.
Here is our web-page which explains its function. I have also attached a picture so you know what you are looking for.
May 1, 2018 at 10:51 AM
RICKYCLEVINGER
  • 7 POSTS
Check engine light is not currently on but goes on and off, has three codes. p0420, p1612, and p0138. Idle speed in park is about 8,000.
May 2, 2018 at 9:12 AM
  • 55,721 POSTS
To me this sounds like and EGR valve problem like it is hung open which will cause all of these problems. Please let me know if the engine has one, they came both ways with and with out the valve.
Here is a video that will show you how to test the valve:
https://youtu.be/DqUCbbKdWf4
If it does not have a valve then it must be the IAC valve stuck open like JACOBANDNICKOLAS is suggesting.
Check out the diagrams (below).
Cheers, Ken
May 6, 2018 at 9:31 AM
RCLEVINGER01
  • 6 POSTS
Ken, as it turns out the vehicle does not have an EGR valve or an IAC valve, it does have an intake manifold runner valve, could this be the culprit?
May 27, 2018 at 1:15 PM
  • 55,721 POSTS
It does not sounds like it. It sounds more like the throttle body or throttle pedal position sensor needs to be replaced. It stalls and revs to 8,000 rpm?
Cheers, Ken
May 28, 2018 at 3:00 AM
