stalling problem
250,000 MILES
ELLYGREEN
my car has been stalling in low speed AREAS NEVER on the express way. I have gutted the catalytic converter I was told that was the problem it was clogged bad but my car is still stalling now stalling more often. when it stalls my brake lock up and cant break I don't know what to do I have 3 kids that travel in this car and very little money I can not just hire a mechanic and I have to get to work please help
May 20, 2013 at 7:45 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuelpressure first. auto parts scan for free
Nov 5, 2018 at 11:07 AM
ELLYGREEN
i have now also changed the air filter the idle air control valve an have used sea foam to clean injectors the only other thing I know to try is spark plugs. will a bad alternator cause is problem? I know the break are not locking up. An when it starts to stall I can sometimes give it gas and it will come out of it.
HMAC300
  • 48,601 POSTS
do what I said in first reply and also clean the throttle plate on both sides with choke cleaner.
