Stalling out while driving. Starts up later on
200,000 MILES
ANDYCAB2105
When van will not start, pull a plug wire, no spark. Pull the coil wire, then U get a spark. Attached coil wire and plug wire, van will start. After running for about 3o minutes, it will stall out. Then nturn the key and will start. The Distributor w/cap, rotor, plug wires, igniton coil and ignition module has been replaced
Apr 12, 2013 at 1:22 AM
KHLOW2008
  • 41,812 POSTS
Is the Malfunction Indicator Light showing and have you checked for trouble codes?
Apr 12, 2013 at 2:14 AM
