Stalling out
93,000 MILES • 5.3L • 2WD • AUTOMATIC
ELISEO COLEMAN
My SUV turned on and i drove it about 2 blocks down it started to lose
acceleration. I parked it. the next day when I put into reverse or drive it turns off and won't stay on. had a bad catalytic converter took it off and still same problem. what could be the problem?
May 9, 2020 at 4:08 PM
Good morning,
Is the check engine light on? If it is, there are fault codes stored. I would need them to narrow the area of failure.
Does the transmission engage and move the car? Trying to determine is the transmission is dropping out.
https://www.2carpros.com/articles/engine-stalls
When it stalls does it start right back up?
https://www.2carpros.com/articles/stall-at-idle
May 9, 2020 at 9:11 PM
