My car stalls when i am turning slowly coming to a stop. It stalls like this five to seven times weekly. Never has stalled going straight stopping. When it stalls it resets my head unit. I've changed IAC, MAF, TPS, EGR, and removed and cleaned throttle body. None of this has helped the stalling issue but has made car run better over all. Not sure if this has anything to do with my key turned to on my battery light stays on and the gauge is low. When I start it the gauge goes up to perfect, but if I turn on A/C voltage drops and kind of bogs car for a second and then it idles up. Any help would be greatly appreciated.
It also maybe temperature related because this only happens after it has warmed up. When it is cold out it barely happens.
Mar 27, 2019 at 8:59 AM
